“BIGIP-11.3.0.39.0-scsi.vmx” is running on Vmware Workstation9.0 but i can only use tls1.0 to access the virtual server.I don’t know why the virtual server always replys tls1.0.
Greetings Mrpre, My guess would be for optimal speed. You could disable TLS1.0 in the SSL profile under the options list section. Also, you could add DEFAULT:!TLSv1 to the ciphers option.
Hope this is helpful, Kevin
