Hello,
I would like to whitelist some IPs in an iRule. The IPs are defined in a datagroup.
Here is my code, but I’m not sure if this works…
when CLIENT_ACCEPTED {
if { ([class match [IP::client_addr] equals datagroup-ntvSamsungSmartTVApp]) } {
pool SmartTV-pool
else {
reject
in Datagroup “datagroup-ntvSamsungSmartTVApp” are the allowd IPs.
Thank you!
if { [matchclass [IP::client_addr] equals datagroup-ntvSamsungSmartTVApp]) } {
pool SmartTV-pool
reject
matchclass
was deprecated starting in v10: https://devcentral.f5.com/wiki/iRules.matchclass.ashx. That first rule does have a couple of extra squirly-braces and unnecessary (though otherwise not harmful) parentheses, which I suspect is the thing @ryan_1 was primarily working to clean up. Taken together:
if { [class match [IP::client_addr] equals datagroup-ntvSamsungSmartTVApp] } {
pool SmartTV-pool
else {
reject
If this is the only logic, however, I believe it is more sensible to assign SmartTV-pool as the default pool to Virtual Server, then do the following:
if { ![class match [IP::client_addr] equals datagroup-ntvSamsungSmartTVApp] } {
reject
When the pool is assigned to the VS by configuration, the Virtual Server status is explicitly bound to this pool, rather than implicitly bound via the iRule.
And, of course, if you have a device with a Better or Best license, AFM performs this function substantially faster.
Thank you guys! I think it works this way:)
I got one more question. I would like to add Geoblocking to this iRule. But it doesn’t work for me.
So Whitelist for one IP + Geoblocking:
switch[ whereis [IP::client_addr] country ] {
"DE" { set allowed 1 }
"AT" { set allowed 1 }
"CH" { set allowed 1 }
"LI" { set allowed 1 }
"LU" { set allowed 1 }
default { set allowed 0 }
elseif {
if {
[matchclass [IP::client_addr] equals datagroup whitelistIP ] } {
pool datagroup-whitelistIP
else {
reject
Is this correct?
