which monitor can implement monitoring link packet loss rate?
Custormer want to monitor the link use BIG-IP LTM. use monitoring link packet loss rate to decision the link status. if packet loss rate is greater than 3% at 60 seconds,send a log.
BIG-IP LTM How to Implement this function.
Thanks a lot.
Thanks a lot.
Could you use packet drop divided by packets in or packets out?
root@(f5)(cfg-sync Standalone)(Active)(/Common)(tmos) show net vlan vlan_client
Net::Vlan: vlan_client
Interface Name      vlan_client
Mac Address (True)  00:00:00:00:00:00
MTU                 1500
Tag                 4094
  | Net::Vlan-Member: 1.1
  | Tagged  no
     | Net::Interface
     | Name  Status  Bits   Bits  Pkts  Pkts  Drops  Errs  Media
     |                 In    Out    In   Out
     | 1.1       up  3.7K  22.3K     9    55      3     0   none
Thank you for you reply. Customer want to use BIG-IP to monior a remote IP(e.g Remote Router IP Addr). If find out packet loss rate is greater than 3% at 60 seconds,send a log. Use this way to find out Link Issue.
