whether default cipers supports to TLS 1.0 in TMOS 13.1.1 or not.
I want to enable TLSv1.2. so i want to confirm that whether default cipers supports to TLS 1.0 in TMOS 13.1.1 or not. and how we can enable the TLSv 1.2 on BIG-IP.
You have all info needed in this article (K13163: SSL ciphers supported on BIG-IP platforms (11.x - 13.x)):
As you can noticed, TLS1.2 is supported in the NATIVE SSL stack in BIG-IP 13.0.0 - 13.1.0.
You don’t need to enable it by default. but you can force it (use only tls1.2). but in this case client that not support tls1.2 will receive a reset.
regards,
