Where icall script are stored in f5 big-ip?
Hi, I need to know where this type of script (icall script)  are stored, and if them can be backed up like a normal file.
Thanks in advance
Cheers
They should be in your bigip_script.conf file, which will always be exported when taking qkview or ucs dumps.
Hi Charlysan,
the iCall Handlers (stored in bigip.conf) and iCall Scripts (stored in bigip_script.conf) are included in a regular backup.
itacs@(kw-f5-dev)(cfg-sync Standalone)(Active)(/Common)(tmos)# list sys icall
sys icall handler periodic F5.AutoSaveConfigScheduledTask {
interval 120
script F5.SaveConfig.OnlyIfModified
sys icall script F5.SaveConfig.OnlyIfModified {
app-service none
definition {
set dbfile_timestamp [exec stat /config/BigDB.dat --format %Z]
set conffile_timestamp [exec stat /config/bigip.conf --format %Z]
if { $dbfile_timestamp > $conffile_timestamp } {
tmsh::save sys config partitions all
description none
events none
If your iCall Scripts execute external BASH scripts, its strongly recommended to store those BASH scripts in directories covered by UCS backups (e.g. /config or /var folder).
Cheers, Kai
