Guys, I’ve been trying to get F5 to setup a permanent connection using OneConnect to a real server but couldn’t make it work.
So, here’s what I have in my setup (all in Lab):
Virtual Server: 111.111.111.111
No default pool member, No persistence profile.
I do a pool redirection using irule, whether it's going to pool A or pool B (different application).
Now the Pool A application team needs this connection to be in permanent connection.
So in pool A node member consists of 192.168.13.250:20000.
I've tried using OneConnect profile in virtual server 111.111.111.111 but to no avail.
I do a tcpdump and see that F5 is actually sending a Reset flag at the end of connection instead of making it permanent for subsequent traffic to use:
14:41:33.166478 IP 192.168.1.100.56678 > 192.168.13.250.20000: R 105:105(0) ack 308 win 4687
Being mindful that all these are SSL packets.
Is there anyway to make this OneConnect works? Or am I missing something?
Come to think of a traffic flow, following my IP address scheme:
A client (IP Address A.B.C.D) connects to Virtual Server 111.111.111.111 (F5)
F5 then forward it to the pool member, in this case 192.168.13.250 on TCP port 20000.
Then after this finishes, the client (A.B.C.D) sends a Reset flag, stating that it has finished sending packet. No more packets left. F5 acknowledges it.
So where and when does the Oneconnect kick in, and how does it keep the TCP 20000 open for other packet to be used?
configuration
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar80
ltm virtual bar80 {
destination 172.28.24.10:80
ip-protocol tcp
mask 255.255.255.255
pool foo80
profiles {
http { }
my1connect { }
tcp { }
rules {
myrule80
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 28
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo80
ltm pool foo80 {
members {
200.200.200.101:80 {
address 200.200.200.101
// to not worry about timeout (when testing), i used indefinite idle timeout.
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm profile one-connect my1connect
ltm profile one-connect my1connect {
app-service none
idle-timeout-override indefinite
testing
// send 1 request to virtual server. client sends FIN after receiving the response.
// anyway, bigip does not forward FIN to server. leave the serverside connection idle to be reusable.
[root@ve11a:Active:In Sync] config tcpdump -nni 0.0 -s0 port 80
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes
00:39:32.181811 IP 172.28.24.1.37779 > 172.28.24.10.80: S 1513065117:1513065117(0) win 5840 in slot1/tmm1 lis=
00:39:32.181893 IP 172.28.24.10.80 > 172.28.24.1.37779: S 1841142685:1841142685(0) ack 1513065118 win 4380 out slot1/tmm1 lis=/Common/bar80
00:39:32.186315 IP 172.28.24.1.37779 > 172.28.24.10.80: . ack 1 win 5840 in slot1/tmm1 lis=/Common/bar80
00:39:32.187614 IP 172.28.24.1.37779 > 172.28.24.10.80: P 1:88(87) ack 1 win 5840 in slot1/tmm1 lis=/Common/bar80
00:39:32.187714 IP 200.200.200.14.37779 > 200.200.200.101.80: S 3626688258:3626688258(0) win 4380 out slot1/tmm1 lis=/Common/bar80
00:39:32.187731 IP 172.28.24.10.80 > 172.28.24.1.37779: . ack 88 win 4467 out slot1/tmm1 lis=/Common/bar80
00:39:32.189422 IP 200.200.200.101.80 > 200.200.200.14.37779: S 1071034751:1071034751(0) ack 3626688259 win 5792 in slot1/tmm1 lis=/Common/bar80
00:39:32.189438 IP 200.200.200.14.37779 > 200.200.200.101.80: . ack 1 win 4380 out slot1/tmm1 lis=/Common/bar80
00:39:32.189490 IP 200.200.200.14.37779 > 200.200.200.101.80: P 1:112(111) ack 1 win 4380 out slot1/tmm1 lis=/Common/bar80
00:39:32.191061 IP 200.200.200.101.80 > 200.200.200.14.37779: . ack 112 win 5792 in slot1/tmm1 lis=/Common/bar80
00:39:32.388023 IP 200.200.200.101.80 > 200.200.200.14.37779: P 1:390(389) ack 112 win 5792 in slot1/tmm1 lis=/Common/bar80
00:39:32.388130 IP 172.28.24.10.80 > 172.28.24.1.37779: P 1:385(384) ack 88 win 4467 out slot1/tmm1 lis=/Common/bar80
00:39:32.388154 IP 200.200.200.14.37779 > 200.200.200.101.80: . ack 390 win 4769 out slot1/tmm1 lis=/Common/bar80
00:39:32.388162 IP 172.28.24.10.80 > 172.28.24.1.37779: F 385:385(0) ack 88 win 4467 out slot1/tmm1 lis=/Common/bar80
00:39:32.392468 IP 172.28.24.1.37779 > 172.28.24.10.80: . ack 385 win 6432 in slot1/tmm1 lis=/Common/bar80
00:39:32.392475 IP 172.28.24.1.37779 > 172.28.24.10.80: F 88:88(0) ack 386 win 6432 in slot1/tmm1 lis=/Common/bar80
00:39:32.392498 IP 172.28.24.10.80 > 172.28.24.1.37779: . ack 89 win 4467 out slot1/tmm1 lis=/Common/bar80
// show sys connection and show oneconnect statistic
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show sys connection protocol tcp
Sys::Connections
any6.any any6.any 200.200.200.14:37779 200.200.200.101:80 tcp 3 (tmm: 1) none
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show ltm profile one-connect my1connect
Ltm::OneConnect Profile: my1connect
Virtual Server Name N/A
Connections
Current Idle 1
Maximum 1
Total Reuses 0
New 1
// after 15 seconds, server sends FIN to close the connection.
00:39:47.413593 IP 200.200.200.101.80 > 200.200.200.14.37779: F 390:390(0) ack 112 win 5792 in slot1/tmm1 lis=/Common/bar80
00:39:47.413636 IP 200.200.200.14.37779 > 200.200.200.101.80: . ack 391 win 4769 out slot1/tmm1 lis=/Common/bar80
00:39:47.413647 IP 200.200.200.14.37779 > 200.200.200.101.80: F 112:112(0) ack 391 win 4769 out slot1/tmm1 lis=/Common/bar80
00:39:47.415217 IP 200.200.200.101.80 > 200.200.200.14.37779: . ack 113 win 5792 in slot1/tmm1 lis=/Common/bar80
// serverside connection is gone
Sys::Connections
Connections
Current Idle 0
Maximum 1
Total Reuses 0
New 1
It appears that F5 is sending the Reset flag. At the end of a packet, F5 decides to send the server an RST flag, thus the oneconnect doesn’t work properly..
Is there anyway to make a permanent connection besides using OneConnect?
Eg: when adding a pool member, I noticed that F5 is actually connecting to the pool member on the specified port. Is it possible to make F5 create a permanent connection at this stage and every other subsequent traffic is using this connection?
Does oneconnect only work with http? I only use TCP..
since you do not use http profile, i understand you may have to manually detach serverside connection (i.e. LB::detach) when transaction is done (because bigip does not know when it is considered complete). this is one of nice articles about oneconnect (anyway it may not answer your question).
OneConnect? For my iRule? by Deb Allen
another method is to use mblb but it is experimental command (i.e. LB::context_id, LB::dst_tag, LB::src_tag).
Ok, so apps team finally have replaced the software and now it no longer sends a RST flag. However OneConnect still doesn’t work. After consecutive 4 or 5 traffic, F5 still opens a new TCP port to the server.
“The OneConnect profile may be used with any TCP protocol, but only when applied to virtual servers that process simple request/response protocols where transaction boundaries are explicitly obvious, such as those in which each request and each response is contained within a single packet.”
However I’ve confirmed that it’s not working for my environment. I took out oneconnect profile, and it works the same.
Anyone have more ideas on how to establish a permanent connection to a pool? Appreciate it.
Hey nitass, I tried that. That didn’t work too. In order for me to have a permanent connection to the pool, I thought I should have it disable? eg: ONECONNECT::detach disable
