Session cookies are stored in memory by the client. No data for cookies is stored on the BIG-IP. This is an advantage of cookie insert persistence.
Can you describe what you’re trying to do and what’s going wrong?
Are you trying to test cookie persistence? Are you trying to persist clients to the same node in the same pool regardless of whether they make a request to one VIP or another?
If you’re on 9.4, you can use a rule like the following to log the Set-Cookie header in responses sent back to clients.
Else, you can use LiveHTTPheaders for Firefox or IEwatch/HTTPwatch for IE to view the cookie headers being sent from the BIG-IP to the client and from the client to BIG-IP.
rule log_cookies_rule {
if {[HTTP::header exists "Cookie"]}{
foreach aCookie [HTTP::cookie names] {
log local0. "Cookie: $aCookie=[HTTP::cookie $aCookie]"
when HTTP_RESPONSE {
If you’ve configured cookie persistence with a named cookie, you should see something like the following logged to /var/log/ltm:
Rule log_cookies_rule : Set-Cookie: persist_cookie=761637056.20480.0000; path=/
On subsequent requests, if the client presents the cookie, you should see:
Rule log_cookies_rule : Cookie: persist_cookie=761637056.20480.0000
The cookie name in the example is persist_cookie. By default it is BIGipServer. The value is an encoding of the node IP address and port. Click here for details on decoding the value. The path is set to a default of / so a client will send the cookie for any requested URI. There is no domain set on the cookie, so it’s host-specific (the client will only send the cookie if it’s making a request to that exact host). If a domain was specified, the client would send that cookie in requests to any host on the domain more specific than the domain specified:
If the client is making requests to app1.example.com and the app specifies no domain on the cookie, the client will only send that cookie in requests to app1.example.com. If app1.example.com set’s the domain to .example.com, then the client “should” present that cookie in requests to any host on the example.com domain.
There are a few requirements in the RFC’s (2109, 2965) which describe when clients should include a cookie with their requests.
http://www.ietf.org/rfc/rfc2109.txt
http://www.ietf.org/rfc/rfc2965.txt
It sounds like you’re trying to persist clients to the same node across multiple virtual servers. To do so, you’d need to add the same persistence profile to both VIPs. The virtual servers would need to be on the same domain (vip1.example.com and vip2.example.com). The pool on each VIP would need to be the same. And the domain set on the cookie would need to be the same for both virtual servers.
To set the domain on the cookie you can use a rule. You should be able to use this example if you haven’t modified the cookie name in the cookie persistence profile:
when LB_SELECTED {
get the pool name used for this request
set my_pool [LB::server pool]
Check if the persistence cookie exists in the response
if {[HTTP::cookie exists "BIGipServer$my_pool"]} {
set the domain attribute on the persistence cookie
HTTP::cookie domain "BIGipServer$my_pool" ".example.com"
Else, if you’ve customized the name, you could use this rule. Make sure to update MY_PERSIST_COOKIE_NAME to the name in the cookie persist profile.
if {[HTTP::cookie exists "MY_PERSIST_COOKIE_NAME"]} {
HTTP::cookie domain "MY_PERSIST_COOKIE_NAME" ".example.com"
I haven’t tested the rule, but the format looks correct.
Aaron
