When I login the system prompt 'Give root password for maintenance (or type Control-D to continue):"
Login incorrect. Give root password for maintenance (or type Control-D to continue): Login incorrect. Give root password for maintenance (or type Control-D to continue): Unmounting file systems Automatic reboot in progress. Error:halid: senRestarting system. GATEWAY IP: 127
PXELINUX/F5 HSIBJ 3.07 Copyright (C) 1994-2005 H. Peter Anvin
Booting from local disk…
GRUB  version 0.93  (639K lower / 4127680K upper memory)
+-------------------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, ‘e’ to edit the commands before booting, ‘a’ to modify the kernel arguments Booting ‘BIG-IP 9.3.1 Build 81.1 - drive hdc.2’
root (hd1,0) Filesystem type is fat, partition type 0xb kernel /boot/2/vmlinuz ro root=UUID=9d6ba18b-3eae-4669-8c78-3796981acb1b consol e=ttyS0,19200 panic=1 mem=384M quiet platform=D68 [Linux-bzImage, setup=0x1400, size=0x1af84a] initrd /boot/2/initrd [Linux-initrd @ 0x17f69000, 0x86ea8 bytes]
Red Hat nash version 3.5.13 starting Mounting /proc filesystem Creating block devices Creating root device Mounting root filesystem INIT: version 2.85 booting Welcome to BIG-IP 9.3.1 Build 81.1 …Not forcing file system integrity check due to default setting .hdc.2-root: clean, 20913/124928 files, 27923/249609 blocks …shared contains a file system with errors, check forced. shared: Inodes that were part of a corrupted orphan linked list found.
shared: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY. (i.e., without -a or -p options) hdc.2-config: clean, 142/124928 files, 8363/249609 blocks hdc.2-var: clean, 1710/749248 files, 82632/1497659 blocks hdc.2-usr: clean, 9594/124928 files, 80796/249609 blocks [FAILED]
CONTACTS COPYRIGHT PLATFORM VENDOR VERSION VERSION.LTM bin boot command config defaults dev etc examples home hotfix image.type initrd lib lost+found mnt opt proc root sbin service shared subdomain tmp ts ts.cfg usr var An error occurred during the file system check. CONTACTS COPYRIGHT PLATFORM VENDOR VERSION VERSION.LTM bin boot command config defaults dev etc examples home hotfix image.type initrd lib lost+found mnt opt proc root sbin service shared subdomain tmp ts ts.cfg usr var Dropping you to a shell; the system will reboot CONTACTS COPYRIGHT PLATFORM VENDOR VERSION VERSION.LTM bin boot command config defaults dev etc examples home hotfix image.type initrd lib lost+found mnt opt proc root sbin service shared subdomain tmp ts ts.cfg usr var when you leave the shell. Give root password for maintenance (or type Control-D to continue):
EUD is suggested. If everything is fine, please consider a clean installation.
