What restrictions will be if my BIG-IP device wil have only ASM license
Hi, i know that if i will license only ASM module i will have some restrictions for load balamcing etc. But i can’t find all restritions. Please help me
Hello Yarosalv Malookiy,
Yes indeed, you have certain limitation without a LTM licence on your F5 BIG-IP.
From memory, you can use only 3 Pools and 2 Load Balancing algorithm are available (Ratio/Round Robin).
Regards
Hello Yaroslav,
I want to add small clarification about it.
ASM module can be provisioned with 2 licenses - ASM license (old one) and AWAF license (new one).
In case of ASM license you will have all these restrictions, which are described above, but with AWAF license you won’t have them.
Thanks, Ivan
i’m telling about standart ASM
Like Ivan said, in Standard ASM license there’s the limitations I’ve indicated above.
If this answer was helpful, please don’t forget to mark the answer as “the best”.
Regards
K14231234: Comparing F5 Advanced WAF and BIG-IP ASM profiles and features
