What is TMM used for in LTM 1600/3600 ?
Also how to check memory & CPU utilisation in LTM1600/3600 LB ?
And also how to check members utilising more memory ?
See 404 Page not found | BIG-IP Documentation
" TMM runs as a real-time user process within the BIG-IP operating system (TMOS). Prior BIG-IP versions handled traffic processing in the kernel.
The following factors influence the manner in which TMM utilizes the CPU:
•The number of processors installed in the BIG-IP system
•The BIG-IP version
•The modules for which the BIG-IP system is licensed "
What is TMM used for in LTM 1600/3600 ?The101: iRules - Introduction to F5 Technology & Terms by Colin
Also how to check memory & CPU utilisation in LTM1600/3600 LB ?isn’t performance graph in gui usable?
And also how to check members utilising more memory ?sorry i do not get you.
Hi Nitass,
Thanx for ur reply & help?
My query is if i receive alert for high memory utilisation alert from BIG-IP LTM 3600.
Then how will check which pool member/node/http request utilising more memory ?
Hi Nitass,
Thanx for ur reply & help.
