Can I use an SSL Cert with a 4096 bit long key? If not, what needs to be adjusted to make this work? Thanks.
Anyone have an update on this? Does 10.x support 4096? I can’t seem to verify the answer.
Hi Steve,
Apparently for client or server SSL, you can use certs/keys larger than 2048 bits if you use software SSL decryption:
From case C564817:
You can specify a cipher string of “DEFAULT:!NATIVE” and the “!NATIVE” will rule out using the acceleration card and just use software.
This is also noted in SOL10580:
SOL10580: The SSL key size is limited when using hardware acceleration
If you open a case with F5 you can ask to have your request added to CR124105.
Aaron
