What could happen after HA is disabled in F5
Hi Two F5 are in Sync. Anyone can tell what could happen after HA is disabled in F5?
Below is what we did
System >>>>> High Availability >>>>> HA Group >>>>> Uncheck Enable box >>>>> click “Update”
If you disable HA Group, you won’t use this feature anymore to trigger failovers on pool and/or trunks loss detection. This might trigger a failover depending on how it’s configured on the peer and what you disable first if you wish to go down that road.
Understanding Fast Failover
This has nothing to do with your existing network or hardware failover configuration though.
Salim
Right, Thank you
