My setup consists of two DC’s with Two GTM’s (Active/Standby) and Two LTM’s (Active/Standby) in each DC. Within the GSLB Trusted Certificate Store, there are certs for each others devices, which I believe is the correct setup. (Each device has 8 certs, of its other devices)…
However I am not sure about what should be in the "System - Certificate Management - Device Certificate Management - Device Trust Certificates store. (This is a bit of a mess, some devices have each others, some don’t etc. Would like to have this cleaned up.
For ease of description will refer to items as the following : -
DC1GTMA - DC1 Active GTM
DC1GTMS - DC1 Standby GTM
DC1LTMA - DC1 Active LTM
DC1LTMS - DC1 Standby LTM
DC2GTMA - DC2 Active GTM
DC2GTMS - DC2 Standby GTM
DC2LTMA - DC2 Active LTM
DC2LTMS - DC2 Standby LTM
The four GTM’s are in a device sync group “DNS - Settings - GSLB - General”…so when you make a change on one GTM, its replicated across all of them. Would this come under IQUERY and thus come under the GSLB Trusted Certificate store, or is this under the Device Trust Store?
First, iQuery is used between the GTM and devices that it wants to gather resource information for. Second, I believe these certs are where they need to be and you shouldn’t have to worry about their respective locations. Finally, your GTM HA configuration is a bit much since GTMs are inherently redundant and adding the additional active/standby configuration is a bit of overkill. I would keep the standby GTMs at each site in a storage cabinet somewhere and if your other GTMs ever fail you can swap them out. The LTMs I would leave as is because that is the ideal HA setup for them. Alternatively, if F5 lets you, you can send the standby GTMs back and get a refund because they really aren’t necessary. If they don’t give you a refund you can install them at 2 other sites and have 4 GTMs worth of redundancy across 4 locations or as I said earlier put them in storage and have them as backups if your live GTM at that respective location.
Thanks for the above, I can see the sense on the need for just one GTM, but its in, and I don’t think I will get much traction with regards to refunds etc, so I will just let it be, but your points are valid.
There was more to my post, but for a reason or another it didn’t post, so here’s another go. I wanted to share, the certs I had in “System - Certificate Management - Device Certificate Management - Device Trust Certificates” as some devices have some certs and its not looking equal so wanted your thoughts on this.
DC1GTMA - has the following certs in its store : -
Itself (is this required, can I remove it?)
DC1GTMS
DC2GTMA
DC2GTMS
DC1GTMS - has the following certs in its store : -
Itself is missing? (Required?)
DC1GTMS
DC2GTMA
DC2GTMS
DC1LTMA- has the following certs in its store : -
DC1GTMA
DC1GTMS
DC2GTMA
DC2GTMS
Missing DC1LTMS (Do I need it here?)
Missing DC2LTMA (Do I need it here?)
Missing DC2LTMS (Do I need it here?)
DC1LTMS - has the following certs in its store : -
DC1GTMA
DC1GTMS
DC2GTMA
DC2GTMS
Missing DC1LTMA (Do I need it here?)
DC2GTMA - has the following certs in its store : -
DC2GTMS
Missing DC1GTMA (Do I need it here?)
DC1GTMS
DC2GTMS - has the following certs in its store : -
DC2GTMA
DC1GTMS
DC2LTMA - has the following certs in its store : -
Missing Itself (Do I need it here?)
DC1GTMA
DC1GTMS
DC2GTMA
DC2GTMS
DC2LTMS - has the following in certs in its store : -
DC1GTMA
DC1GTMS
DC2GTMA
DC2GTMS
Forgive me for the detail, but hoping it makes things easier to grasp. I have put a comment where I am not sure, but if you think, I can make this simpler, please do comment inline, and advise if this list on the devices can be cleaned up.
