the virtual command basically used the specified VS instance as a pool member. The connection flow would be CLIENT ↔ FrontEndVS ↔ BackEndVS and vice versa.
Use the Virtual Server and iRule setup below to see the involved OSI layers and iRule events in action to serve a single GET request. The log file at the buttom shows you the order of the individual iRule events on both Virtual Servers…
[root@f501:Active:Standalone] config tmsh
root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) load sys config merge from-terminal
Enter configuration. Press CTRL-D to submit or CTRL-C to cancel.
ltm virtual VS_FrontEnd {
destination 172.22.17.223%1:https
ip-protocol tcp
mask 255.255.255.255
profiles {
clientssl {
context clientside
serverssl {
context serverside
http { }
tcp { }
rules {
iRule_FrontEnd
source 0.0.0.0%1/0
translate-address enabled
translate-port enabled
ltm virtual VS_BackendEnd {
destination 172.22.17.224%1:https
ip-protocol tcp
profiles {
clientssl {
context clientside
http { }
tcp { }
rules {
iRule_BackEnd
source 0.0.0.0%1/0
ltm rule iRule_FrontEnd {
when CLIENT_ACCEPTED {
log local0.debug "Client [IP::client_addr]:[TCP::client_port] connected to VS_FrontEnd on [IP::local_addr]:[TCP::local_port]."
when CLIENTSSL_HANDSHAKE {
log local0.debug "Client [IP::client_addr]:[TCP::client_port] esatblished TLS Channel with VS_FrontEnd on [IP::local_addr]:[TCP::local_port]."
log local0.debug "Client [IP::client_addr]:[TCP::client_port] requested URI = [HTTP::uri]."
when SERVER_CONNECTED {
log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] is connecting to VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]."
when SERVERSSL_HANDSHAKE {
log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] established TLS Channel with VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]."
when HTTP_REQUEST_SEND {
log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] is forwarding the HTTP request to VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]."
when HTTP_RESPONSE {
log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] got a HTTP response from VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]"
when HTTP_RESPONSE_RELEASE {
log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] is forwarding the HTTP response to Client on [IP::client_addr]:[TCP::client_port]"
ltm rule iRule_BackEnd {
log local0.debug "VS_FrontEnd using [IP::client_addr]:[TCP::client_port] connected to VS_BackEnd on [IP::local_addr]:[TCP::local_port]."
log local0.debug "VS_FrontEnd using [IP::client_addr]:[TCP::client_port] esatblished TLS Channel with VS_BackEnd on [IP::local_addr]:[TCP::local_port]."
log local0.debug "VS_FrontEnd using [IP::client_addr]:[TCP::client_port] requested URI = [HTTP::uri]."
log local0.debug "Sending HTTP response to VS_FrontEnd on [IP::client_addr]:[TCP::client_port]."
HTTP::respond 200 content "OK"
}Loading configuration...
root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) quit
[root@f501:Active:Standalone] config tail -f /var/log/ltm
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : Client 172.21.92.19%1:52406 connected to VS_FrontEnd on 172.22.17.223%1:443.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : Client 172.21.92.19%1:52406 esatblished TLS Channel with VS_FrontEnd on 172.22.17.223%1:443.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : Client 172.21.92.19%1:52406 requested URI = /.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 is connecting to VS_BackEnd on 172.22.17.224%1:443.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : VS_FrontEnd using 172.21.92.19%1:52406 connected to VS_BackEnd on 172.22.17.224%1:443.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 established TLS Channel with VS_BackEnd on 172.22.17.224%1:443.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 is forwarding the HTTP request to VS_BackEnd on 172.22.17.224%1:443.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : VS_FrontEnd using 172.21.92.19%1:52406 esatblished TLS Channel with VS_BackEnd on 172.22.17.224%1:443.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : VS_FrontEnd using 172.21.92.19%1:52406 requested URI = /.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : Sending HTTP response to VS_FrontEnd on 172.21.92.19%1:52406.
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 got a HTTP response from VS_BackEnd on 172.22.17.224%1:443
Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.22.17.223%1:443 is forwarding the HTTP response to Client on 172.21.92.19%1:52406
^C
Note: If you look carefully to the resulting log file of this demo setup, you will notice that the FrontEnd Virtual Server will even negotiate a TLS channel with the BackEnd Virtual Server. So better make sure the FrontEnd Virtual Server does not utilize a ServerSSLProfile and the BackEnd Virtual Server does not utilize a ClientSSLProfile.
