I have several pairs of LTM’s connecting to Cisco to 2960G48TLL switches running code 12.2.25. The LTM’s are on version 10.x. I have configured a trunk on each LTM and I have added interfaces 1.1 and 1.2 to each trunk. I am using tagged VLAN’s. I am not using LACP and the interfaces are hard set to 1000/full at both the switch and LTM. The rest of the configurations on the trunk and interfaces are set to the default values.
The interfaces are connected and reachable via pinging. I have a continuous ping reaching the devices and then after a couple of hours it drops and times out. Then after another long period it re-establishes connectivity and is pingable again. Anyone ever seen this behavior? I have about 5 pairs that keep behaving the same way. My company is not open to using LACP and apparently there are devices configured in this fashion that are working in production. Anyone ever seen this type of behavior? Any ideas? Thanks…below you will see the port-channel config on the switch and the bigip_base.conf.
Switch Config:
interface Port-channel1
description sf45-iaedev-ltm1
switchport access vlan 999
switchport trunk allowed vlan 26,27,30,32,36,37,39,117,118
switchport mode trunk
end
interface GigabitEthernet0/12
description sf45-iaedev-ltm1-i1
speed 1000
duplex full
no cdp enable
channel-group 1 mode on
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
end
interface GigabitEthernet0/13
description sf45-iaedev-ltm1-e1
speed 1000
duplex full
no cdp enable
end
Bigip_base.conf:
end
speed 1000
duplex full
no cdp enable
end
speed 1000
duplex full
no cdp enable
end
