I have a VIP configured - 192.168.51.125 listening on port 25.
It has a pool with a single host - 192.168.31.17, which has been added to the pool using port 25.
The VIP has SNAT enabled, and all other defaults.
Now from my test sever i can ping 192.168.51.125 and i can telnet to 192.168.51.125 on port 25. But it seems as though the F5 just drops the traffic.
Running TCPDUMP on the F5 shows my traffic hitting the VIP on port 25, but the host (192.168.31.17) never receives the traffic. TCPDUMP on the host shows nothing at all.
From the F5 i can telnet to 192.168.31.17 on port 25 and ping it and all that, but when traffic hits the VIP it doesn’t go any further…
This bigip needs a bit of work I think. If I change the mgmt subnet and create a self op for that vlan I’d say or would work. yes, it would work. normally, pool has to be reached by tmm interface - not mgmt interface.
There is not any issue with changing the management interface right? are you using network failover? in v10, mgmt ip is also used in network failover setting.
VIPs and everything will continue to work as normal? The mgmt interface can’t be used for SNATS or anything like that can it?yes.
