Webtop portal in an iFrame
Is there a way to allow a webtop to be opened in an iframe?
As of right now we’re getting an error “This content cannot be displayed in a frame”
I understand the security risks, but.. the customer is always right.
I’d link to bump this post, as i’ve got kind of the same problem. My customer likes to embed the webtop (by using a iFrame) in his own portal. (Said portal is hosted on the same F5 units, under the same dns domain by the way.)
I managed to clear most of the webtop’s default layout using the advanced customization mode, and even disabled the ‘framekiller’ javascript line below in ‘login.inc’.
`(if(self != top) { top.location = self.location; })`
Unfortunately the webtop also sends a HTTP header “X-Frame-Options” with a value of “DENY”, which prevents the browser from loading the webtop in a iFrame. I tried replacing the header with a iRule, but for some strange reason that won’t work either :disappointed_face:
when HTTP_RESPONSE {
    HTTP::header replace "X-Frame-Options" "SAMEORIGIN"
This just adds another X-Frame-Options header with a value of “SAMEORIGIN” and does not replace the exsisting …
So, i am wondering, is there a specific reason why a webtop cannot be used in a iframe? Has anyone managed to load a webtop in a (i)frame ?
Thanx, Remco.
