I tried to add a SmartAccess policy to a webtop but it does not seem to work. The documentation reference seems to indicate that it is only supported when you deploy in web interface lb mode.
It certainly works with the webtop mode as well - but it is key that 'Trust XML Requests" setting in the XenApp AppCenter Computer Policy be enabled. I’ve seen plenty of cases where that setting was updated and somehow did not take effect until the XML Broker was rebooted - although normally a simple “gupdate” command should be enough.
