I am trying to find a solution for application that will be running in Websphere Application Server V7 version using IBMs JDK 1.6 version that will communicate with BigIP to manage the configurations. I am initializing the BigIP and invoking the XTrustProvider.install method to set the security.
private void initialize(UsageTypeEnum useType) throws Exception
lbinterface = new Interfaces();
lbinterface.initialize(address, username, password);
logger.info(“User Home :” + System.getProperty(“user.home”));
System.setProperty(“javax.net.ssl.trustStore”, System.getProperty(“user.home”) + “/.keystore”);
XTrustProvider.install();
On execution, I am getting the following error:
INFO: ssl.disable.url.hostname.verification.CWPKI0027I
Exception in thread “main” java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:599)
at com.trp.virtualserver.clientutil.ServiceInvocationHandler.fireMethod(ServiceInvocationHandler.java:99)
at com.trp.virtualserver.clientutil.ServiceInvocationHandler.invoke(ServiceInvocationHandler.java:68)
at $Proxy0.getVirtualServerGroup(Unknown Source)
at com.xyz.virtualserver.driver.VirtualServerRetrieveDriver.main(VirtualServerRetrieveDriver.java:25)
Caused by: java.lang.NullPointerException
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:154)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:165)
at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
at org.apache.axis.client.Call.invoke(Call.java:2767)
at org.apache.axis.client.Call.invoke(Call.java:2443)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
at iControl.LocalLBVirtualServerBindingStub.get_list(LocalLBVirtualServerBindingStub.java:2395)
at com.xyz.virtualserver.admin.VirtualServerManager.getVirtualServers(VirtualServerManager.java:142)
at com.xyz.virtualserver.admin.VirtualServerAdmin.getVirtualServerGroup(VirtualServerAdmin.java:107)
… 8 more
at com.ibm.websphere.ssl.protocol.SSLSocketFactory.createSocket(SSLSocketFactory.java:560)
at org.apache.axis.components.net.JSSESocketFactory.create(JSSESocketFactory.java:92)
at org.apache.axis.transport.http.HTTPSender.getSocket(HTTPSender.java:191)
at org.apache.axis.transport.http.HTTPSender.writeToSocket(HTTPSender.java:404)
at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:138)
… 20 more
If I run with the Sun JDK (1.6.17), I am able communicate without any issues. I added the following two jar files to resolve classdef not found errors:
com.ibm.ffdc.jar, com.ibm.ws.security.crypto.jar
Thanks for your help.
