WebLogic Persistence issue.
We have deployed several BEA WebLogic applications, all with JSessionID persistence, without issue.
Now we are deploying a new Application using a renamed JSessionID cookie for persistence, and we are seeing issues with finding the value in our persistence table consistently. Watching communication, we see will see a number of requests hit the iRule we are using, and find the persistence record, and persist. Every now and then it will not find a value for persistence, and load balance to an improper server. Anyone have any ideas?
Note: We are also doing some static content separation to an Apache farm.
if { [ matchclass [HTTP::path] ends_with $::WLfiles ] } {
WebLogic Request
pool weblogic_pool
if { [HTTP::cookie exists “CookieID”] } {
set PersistValue [persist lookup uie [HTTP::cookie “CookieID”]]
if {$PersistValue eq “”} {
log local0.info “no persistance found, even though cookie exists”
persist uie [HTTP::cookie “CookieID”]
Static Request
pool Static-Content_pool
when HTTP_RESPONSE {
persist add uie [HTTP::cookie “CookieID”] 3600
what is the format of your cookie? It’s been awhile, but in an environment I’ve worked in it was <52characterString>!! or something like that. Sometimes, the server IDs would change coming back from the app, tanking persistence when using the whole cookie. I stripped off the serverID stuff and just went with the ID itself using getfield:
[getfield [HTTP::cookie “CookieID”] “!” 1]
Not sure this is your same scenario, but something to consider.
Our Weblogic persistence uses a cookie insert persistence method. This seems to be what the F5 guide and the BEA Weblogic template uses as well.
It works _most_ of the time. However, we do see entries in the weblogic logs that indicate that from time to time a request comes in and falls on the wrong server (not the primary or secondary weblogic server). That puts weblogic into a recovery state to reconstruct the session on the server that it arrived on.
Sounds very similar to the situation Moose reports above. Thanks for the code snippet. I think I can use it for a variation to log when this occurs and capture some information to try to determine what happened.
I’d also be interested in anyone who has found a solution to this situation. Save me the work of trying figure this one out-- guessing it will take a bit to do that.
Thanks!
Hi Brad,
On a tangent, you could try an iRule which uses the primary and secondary session mirroring and tokens on Weblogic to persist clients:
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1171255/showtab/groupforums/Default.aspx1172496
Make sure to add a OneConnect profile to the virtual server.
Aaron
