Weblog export problem
Hi All
I have some question about weblog export.
I have set Http Virtual Server into F5 ( BIG-IP 11.2.1 Build 807.0 Hotfix HF1) , then how to export web log using W3C format?
is this usable?
Formatted Logging For W3c
Tks nitass, I will go to reivew.
One more question, how to check the object if I enable optimized-caching? And it will be logging if object caching?
Tks!
how to check the object if I enable optimized-caching?is this what you are asking?
sol13255: Displaying and deleting RAM Cache entries from the command line (11.x)
And it will be logging if object caching? HTTP_RESPONSE is not triggered when object is retrieved from cache. HTTP_RESPONSE_RELEASE is triggered. however, some HTTP:: command is not available such as HTTP::status.
HTTP_RESPONSE_RELEASE Wiki
Tks nitass, Displaying and deleting RAM Cache is useful for me.
On HTTP_RESPONSE_RELEASE , it cannot be trigger HTTP action like get or HTTP return code … etc?
On HTTP_RESPONSE_RELEASE , it cannot be trigger HTTP action like get or HTTP return code … etc?http method (e.g. GET) is saved since HTTP_REQUEST event. HTTP::status command is not valid in HTTP_RESPONSE_RELEASE event.
HTTP::status Wiki
anyway, to have status code in log, you may use 2 virtual servers and call 2nd virtual server from the 1st one.
e.g.
frontend virtual server (using virtual command and log)
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar-frontend
ltm virtual bar-frontend {
    destination 172.28.20.14:80
    ip-protocol tcp
    mask 255.255.255.255
    profiles {
        http { }
        tcp { }
    rules {
        myrule-frontend
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vlans-disabled
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule-frontend
ltm rule myrule-frontend {
    Save Request Side Information
   set http_request "\"[HTTP::method] [HTTP::uri] HTTP/[HTTP::version]\""
   set http_request_time [clock clicks -milliseconds]
   set http_user_agent "\"[HTTP::header User-Agent]]\""
   set http_host [HTTP::host]
   set http_username [HTTP::username]
   set client_ip [IP::remote_addr]
   set client_port [TCP::remote_port]
   set http_request_uri [HTTP::uri]
   set referer [HTTP::header value referer]
   virtual bar-backend
   log local0. "--"
when HTTP_RESPONSE {
   set response_time [expr [clock clicks -milliseconds] - $http_request_time]
   set virtual [virtual]
   set content_length 0
   if { [HTTP::header exists "Content-Length"] } {
      set content_length [HTTP::header "Content-Length"]
   set lb_server "[LB::server addr]:[LB::server port]"
   if { [string compare "$lb_server" ""] == 0 } {
      set lb_server ""
   set status_code [HTTP::status]
   set content_type [HTTP::header "Content-type"]
   set log_msg ""
   append log_msg "virtual=$virtual "
   append log_msg "client_ip=$client_ip "
   append log_msg "client_port=$client_port "
   append log_msg "lb_server=$lb_server "
   append log_msg "host=$http_host "
   append log_msg "username=$http_username "
   append log_msg "$http_request_uri "
   append log_msg "request=$http_request "
   append log_msg "server_status=$status_code "
   append log_msg "content_type=$content_type "
   append log_msg "content_length=$content_length "
   append log_msg "resp_time=$response_time "
   append log_msg "user_agent=$http_user_agent "
   append log_msg "referer=$referer"
   log  local0. $log_msg
   log local0. "--"
 backend virtual server (using optimized-caching profile)
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar-backend
ltm virtual bar-backend {
    destination 1.1.1.1:80
    ip-protocol tcp
    pool foo
    profiles {
        http { }
        tcp { }
    rules {
        myrule-backend
    source 0.0.0.0/0
        type automap
    vlans-disabled
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule-backend
ltm rule myrule-backend {
        log local0. "--"
        log local0. "--"
 1st request (object is not cached yet)
[root@ve11a:Active:Changes Pending] config  tail -f /var/log/ltm
Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-frontend : --
Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-backend : --
Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-frontend : virtual=/Common/bar-frontend client_ip=172.28.19.251 client_port=34313 lb_server=1.1.1.1:80 host=172.28.20.14 username= request="GET / HTTP/1.1" server_status=200 content_length=89 resp_time=6 user_agent="curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5]" referer=
 object is cached
[root@ve11a:Active:Changes Pending] config  tmsh show ltm profile ramcache optimized-caching
Ltm::Ramcaches /Common/optimized-caching
Host: 172.28.20.14
URI : /
  Source Slot/TMM  1/0
  Owner Slot/TMM   1/1
  Rank             1
  Size (bytes)     353
  Hits             0
  Received         2013-01-10 05:12:15
  Last Sent        2013-01-10 05:12:15
  Expires          2013-01-11 05:43:58
  Vary Type        none
  Vary Count       1
  Vary User Agent  none
  Vary Encoding    none
Total records returned: 1
 2nd request
 you can see HTTP_RESPONSE in myrule-backend is not executed because object is retrieved from cache
Jan 10 13:12:40 ve11a info tmm[11170]: Rule /Common/myrule-frontend : --
Jan 10 13:12:40 ve11a info tmm[11170]: Rule /Common/myrule-backend : --
Jan 10 13:12:40 ve11a info tmm[11170]: Rule /Common/myrule-frontend : virtual=/Common/bar-frontend client_ip=172.28.19.251 client_port=34314 lb_server=1.1.1.1:80 host=172.28.20.14 username= request="GET / HTTP/1.1" server_status=200 content_length=89 resp_time=0 user_agent="curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5]" referer=
