Hello all,
Does anyone know how detect a web dav (Propfind method) request using IRules and then reject it?
Any kind of help is fully appreciated.
Thanks.
Regards,
TRX
Hello all,
Thanks.
Regards,
TRX
Hi TRX,
It would be more secure to positively define which request methods you want to allow and block all others. Here is an example which uses a string type datagroup with the allowed HTTP request methods defined. You can define the datagroup in the GUI under Local Traffic >> iRules >> Datagroup List tab.
class allowed_methods_class {
"GET"
"HEAD"
"POST"
You can then define an iRule which references the datagroup. If you’re on a version lower than 9.4.4 prepend a $:: to the datagroup name in the iRule only: $::allowed_methods_class.
Check if request method is in the allowed_methods_class
if {not [matchclass [HTTP::method] equals allowed_methods_class]}{
Illegal request method, send a 405 - Method Not Allowed response
HTTP::respond 405
Aaron
