Hello,
I have some problems when implementing cookie persistence for an Oracle WebCenter pool . The problem is that when i add persistence using an irule, the value is not mantained and the persistence fails.
I have writed this irule to troubleshoot the problem. Please, any clue if is possible to enhance the solution? Or i have any mistake on the writed fields.
when HTTP_REQUEST priority 300 {
if { [HTTP::cookie "F5test"] ne "" } {
pool "p_evo_wl"
persist uie [HTTP::cookie "F5test"]
if {[HTTP::cookie "F5test"] starts_with "f5id_"}{
HTTP::cookie remove "F5test"
pool "p_evo_wl"
when HTTP_RESPONSE {
if { [HTTP::cookie “F5test”] eq “” }{
set rndumb "f5id_[expr { int(100000000 * rand()) }]"
HTTP::cookie insert name "F5test" value $rndumb"
persist add uie $rndumb 14400
persist add uie [HTTP::cookie "F5test"]
Many thanks in advance!
Javier
I suspect this;
should be;
persist add uie [HTTP::cookie value "F5test"]
nitass
May 28, 2014, 12:47pm
3
i do see client sending cookie back to virtual server in the next request. persistence record seems to be created properly.
by the way, why do you have to change cookie value on every response?
nitass
May 28, 2014, 12:49pm
4
1st request
[root@ve11a:Active:In Sync] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 192.168.206.174(65089) - 172.28.24.10(80)
1401280870.9567 (0.0075) C>S
GET / HTTP/1.1
Accept: application/x-ms-application, image/jpeg, application/xaml+xml, image/gif, image/pjpeg, application/x-ms-xbap, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
Accept-Language: en-US
User-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.3; MS-RTC LM 8; .NET4.0E)
Accept-Encoding: gzip, deflate
Host: 172.28.24.10
Connection: Keep-Alive
New TCP connection 2: 200.200.200.14(65089) - 200.200.200.101(80)
1401280870.9589 (0.0019) C>S
GET / HTTP/1.1
Host: 172.28.24.10
1401280871.0251 (0.0662) S>C
HTTP/1.1 200 OK
Date: Wed, 28 May 2014 12:30:36 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Sun, 09 Feb 2014 08:39:51 GMT
ETag: "41879c-59-2a9c23c0"
Accept-Ranges: bytes
Content-Length: 89
Keep-Alive: timeout=15, max=100
Content-Type: text/html; charset=UTF-8
snipped
1401280871.0264 (0.0697) S>C
HTTP/1.1 200 OK
Content-Length: 89
Set-Cookie: F5test=f5id_42112601";
snipped
2nd request
1401280871.1038 (0.0773) C>S
GET /f5.gif HTTP/1.1
Accept: */*
Referer: http://172.28.24.10/
Host: 172.28.24.10
1401280871.1040 (0.0788) C>S
Accept: */*
Host: 172.28.24.10
persistence record
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show ltm persistence persist-records
Sys::Persistent Connections
universal f5id_86485162 172.28.24.10:80 200.200.200.101:80 (tmm: 0)
universal f5id_42112601 172.28.24.10:80 200.200.200.101:80 (tmm: 0)
universal f5id_86485162 172.28.24.10:80 200.200.200.101:80 (tmm: 1)
universal f5id_42112601 172.28.24.10:80 200.200.200.101:80 (tmm: 1)
universal f5id_56125535 172.28.24.10:80 200.200.200.101:80 (tmm: 1)
Total records returned: 5
