Probably a very simple question but what is the url for adding a web reference in my code. I have created a very simple web form which to be honest is a copy of the F5 tutorial on using C to create an app to manage nodes on the F5 BIG-IP devices. however, when I put the ip address in the url for the f5 appliances all I get back is either the login page for the admin console on the f5 devices or if I add /icontrol I get an error page. Do I need to enable a web service on the F5 device first or is there a particular url I should be using? I am working with BigIP version 9.1.0.
In VS.NET, when adding a WebReference, try entering:
https://your_bigip_address/iControl/iControlPortal.cgi
This will return a list of the available WSDLs, and you can just add the one you need.
Regards,
Loc
Thank you that was exactly what I was looking for.
-a
