Web Portal - APM
We have a portal with links to CRM,Sharpoint and so. The links are accessable only from the lan or VPN. we dont we to publish the DNS of the internal links(CRM,Sharepoint, etc)
Is there an way to publish the portal over the WAN, and still get access to internal links(CRM,Sharepoint, etc) ?? Is it possibale to do it with APM ? (kind of revers proxy)
Thank you.
Yes, you can with APM. There are several options.
1.
Create a VS within LTM and publish the applications on the internet. Add a Access Profile (APM) to the virtual server so you can protect the website with the autentication you want. Add a client side SSL profile for extra security.
But this is not want you want, so…
2.
Use APM to create a Full Webtop (SSL portal), create Portal Access links for the internal websites and add them to the Full Webtop. Configure the desired authentication methode. Use the Full Webtop and Portal Access links to create an Access Policy within a Access Profile and add Access Profile to a virtual server.
3.
Create within APM a Network Access resource so you have full access to internal applications and website. Just like client-to-site VPN.
Hopes this helps.
Regards, Martijn
