Hi All,
When performing a tmsh load sys config verify, I have the following warning message:
/Common/irule_reverse_proxy_v4.1:90: warning: [variable reference used where variable name expected][${var}] /Common/irule_reverse_proxy_v4.1:93: warning: [variable reference used where variable name expected][${var}] /Common/irule_reverse_proxy_v4.1:100: warning: [variable reference used where variable name expected][${var}] /Common/irule_reverse_proxy_v4.1:108: warning: [variable reference used where variable name expected][${var}]
The block responsible for these warnings in my iRule is:
89 foreach var { "do_host_rewrite" "do_requests_rewrite" "do_responses_rewrite" "rule_debug" }
90 {
91 set ${var} 0
92 if {[class search $datagroup equals $var]}
93 {
94 set ${var} [class match -value $var equals $datagroup]
95 }
96 }
This is NOT 404 Page not found | BIG-IP Documentation
I tried the iRule with different version (11.6.0, 11.5.3 etc.)
Is there something wrong with my syntax?
Thank you in advance for your help,
Regards,
