warning tmm3[11615]: 01260013:4: SSL Handshake failed for TCP
Hi Team ,
We have an SSL error message on F5 :  warning tmm3[11615]: 01260013:4: SSL Handshake failed for TCP (error from same single source )
We did not find any logs for VIP down or backend server down at the time of above SSL error message .
Can you please advice what could be the issue in this case .
VIP :433
Backend server listening on port 8040
SSL-client profile applied (only ssl offloading)
The peer closes the connection before the SSL handshake completes. For more information take tcpdump and see if any unusual behaviour
Hi Samir ,
This was one time issue between specified time , So except SSL handshake logs we do see any other abnormality .
When you say peer closes the connection , Do you mean F5 << >> Pool member connection ? , In this case also VIP and pool members where not down .
Its early to comments without seeing tcpdump. Did you capture tcpdump?
the incident happened on 29th and the issue reported to us today , so no tcpdump .
Open support case and let see the RCA
