Wanted to use same public IP for different VS
I have set up multiple Virtual servers(VS) on F5 LTM and wanted to use only one public IP to map to all different VS (i.e,that supports different url’s which are hosted on different VS) & also public IP can be mapped on FireWall with only one VIP.
I’m new to this kind of requirement. Kindly help me how can I achieve this requirement.
Regards, Rajneesh
You could use a layered VS concept to accomplish that. Have your public IP NATed to VS and use local traffic policy to forward traffic to your target virtual servers based on host names.
Example:
On LTM, We have three different Virtual servers (VIP’s) created with different pool names and different members hosting different url’s, which should be accessible via internet.
VIP1-Pool1-node1+node2-- host x.abc.com website
VIP2-Pool1-node3+node4-- host y.abc.com website
VIP1-Pool1-node1+node2-- host Z.abc.com whebsite
But we have only one public IP to do NAT FW and achieve this functionality.
I think either one can be used Name based virtual hosting or http host header but I’m not aware which one and how to proceed
Please suggest a way get this working.
OK, here is what I am suggesting: Create another virtual server on Big-IP (let’s name it VIP-PXY). Nat public IP to this VS on the FW. This VS (VIP-PXY) will not be associated with any pools. Instead you will use a local traffic policy to forward inbound http traffic to VIP1, VIP2, VIP3 based on hostnames. You will need to create LT policy as follow:
Create new Local traffic policy
Strategy: first-match
Requires: http
Controls: forwarding
Now you will need to create 3 rules (one for each host name)
Rule1:
IN conditions section specify below:
Operand:http-host
Event:  request
Selector:host
Condition:equals
Values:x.abc.com
In Actions sections specify following:
Target: forward
Event:  request
Action: select
Parameters: virtual-server
Value: select VIP1 from dropdown (VIP1, VIP2 and VIP3 all need to be in the same partition)
Now create 2 more rules for VIP2 (y.abc.com) and VIP3 (z.abc.com) based on the policy rule for VIP1.
Associate policy with VS (VIP-PXY) under VS resources. You will need to associate http profile with VS (VIP-PXY) and set address translation to SNAT AutoMap.
Alex solution is the solution to hide several virtual servers behind one virtual server. But are you sure you need one virtual server per URL?
you can create only one virtual server with the same logic as alex gave but with action :
forward select pool Pool1
