Hi experts, we are running ver 11.5.1 hf3 on our LTMs. I am using the ifile feature to send out a maintenance page by using the below irule -
when HTTP_REQUEST { if { [active_members [LB::server pool]] < 1 } { HTTP::respond 200 content [ifile get MY-HTML-IFILE] } }
My problem is, i want to insert the no cache, no store headers with it to avoid any kind of caching on the browsers. When i add this line in the irule and test, it breaks the VS - HTTP::header insert Cache-Control “no-store, no-cache”
How can i accomplish this?
HTTP::header insert
in the HTTP_REQUEST event inserts the headers in the request before passing the request to the forwarding target (generally a pool member). Since you are not passing the request along, that’s not quite what you want.
The HTTP::respond command allows you to insert headers directly on the response:
HTTP::respond 200 content "[ifile get MY-HTML-IFILE]" noserver "Cache-Control" "no-store, no-cache"
HTTP::header insert
Thanks… that works !! You are bang on target !!
