w3c iRule logging for Virtual Servers having http to https redirection iRule
I have been asked to verify the VS without w3c iRule in our LTMs and attach this iRule to them. Now, I have many VS in LTMs which have http to https redirection iRule attached to them and w3c iRule attached to VS listening on https.
Could anyone of you please confirm whether I have to attach w3c iRule to both VS listening on http and https or would it suffice if I only attach it to VS with https as requests to http would be redirected to https VS. If I add w3c to both of the VS (http & https) would this create redundant logs as traffic to VS:http are redirected to VS:https.
Can I have some clarification on this.
Thanks in advance, MSK
i think only https virtual server. i understand HTTP_RESPONSE is not triggered by HTTP::redirect command.
e.g.
[root@ve11c:Active:In Sync] config  tmsh list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:80
    ip-protocol tcp
    mask 255.255.255.255
    profiles {
        http { }
        tcp { }
    rules {
        _sys_https_redirect
        qux
    source 0.0.0.0/0
    vs-index 8
[root@ve11c:Active:In Sync] config  tmsh list ltm rule qux
ltm rule qux {
  log local0. ""
when HTTP_RESPONSE {
  log local0. ""
[root@ve11c:Active:In Sync] config  curl -i http://172.28.24.10
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
[root@ve11c:Active:In Sync] config  cat /var/log/ltm
Mar  6 11:19:34 ve11c info tmm[14163]: Rule /Common/qux :
e.g.
ltm virtual bar {
    ip-protocol tcp
    profiles {
        http { }
        tcp { }
    rules {
        _sys_https_redirect
        qux
    source 0.0.0.0/0
    vs-index 8
ltm rule qux {
  log local0. ""
  log local0. ""
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
Hi nitass, thanks for the quick response. I have the redirection rule as : when HTTP_REQUEST { HTTP::redirect “https://[HTTP::host][HTTP::uri]” }
you see both (your irule and _sys_https_redirect) use HTTP::redirect command to redirect.
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule _sys_https_redirect
ltm rule _sys_https_redirect {
    nodelete nowrite
       HTTP::redirect https://[getfield [HTTP::host] ":" 1][HTTP::uri]
definition-signature mwyl4XlRKRMQc0prWs7RtpgPcNfocOKb+MaFwAnQgAuUZZyG68OaGZsOCN3poUOFdHOc6fk2XAdGRmTRiP/7BCT7thsOX5zLFzA1N1wcr57KWVzEZt3ezxVXn2Z974OmbWm7P5Lclcr7N3adrLJMWfyfPPVF1tUYn0IQPD2QNMmfbcbr1oCuO93n/5dn0s6/EacHZGG53hVibW7xQuJXdMtoQ6ArSZ4U3n4vCDTb6NLYbAj6PirVzKY2pcsWFHFUSVrphSFwERc8+0XGHUE6Cb3ihzygoZc2cQ5jk3frFY70MkDluPTShFRbHd7PlMPRezrfkVZVeUHA/iBPcYcD+w==
    verification-status signature-verified
    nodelete nowrite
okay. So its enough if we attach w3c iRule only to VS:https instead of both VS:https & VS:http ??
okay. So is it sufficient if we attach w3c iRule only to VS:https instead of both VS:https & VS:http ???
i think so.
i think so.
In which case, how we going to log the http traffic coming to the VS ??? As per my understanding the http requests would be forward to VS:https via http:redirect command and then would logged as the VS:https would have the w3c iRule. So, wondering how to log the VS:http traffic.
if you put log command in HTTP_REQUEST, you will get log when client hits http virtual server.
Hi nitass, sorry I didnt get you ?? Can you please elaborate on it. Requirement is to log all the web traffic on our internet facing BIG-IP, which is achieved by attaching w3c iRule but I’m confused for the VS which have both http & https wherein the http VS have https redirection rule.
