Vulnerability Diffie-Hellman F5
Hello,
I have a vulnerability ==> Diffie-Hellman group smaller than 2048 bits Someone can explain me, how i can modify my profile SSL Client ?
Thank you in advance for your feedback.
You can disable
!DHE
from current cipher list for specific client ssl profile. Go through link. It may help you.
Thank you for your response :slight_smile:
You’ll need to edit the Ciphers field on the client ssl profile. If you haven’t edited that field, you’ll have the ‘DEFAULT’ cipher stack for the BigIP version you’re running.
If you want to get rid of DHE ciphers all together you can fill the Ciphers field with:
DEFAULT:!DHE
If you want to see which cipher suites you currently have vs. which ones will be left with a new Ciphers value just issue the following command from the bash shell:
tmm --clientciphers DEFAULT
tmm --clientciphers ‘DEFAULT:!DHE’
V14:
V11-V13:
V10:
DEFAULT:!DHE
V14:
V11-V13:
V10:
For your reference: https://devcentral.f5.com/questions/dhe-1024-bits-vulnerability-solved-47853.
Thank you
Thank you
