Hi there,
i hope you are doing well, i’m checking that has a virtual server wildcard a performance l4 and has a pool, and has one pool address that is the gw from the upstream vlan is the external vlan in this example is the 1.1.1.0
so in here is marking like a tcp, so when a i make a ping from the vlan internal in this example 2.2.2.0 host to another host in the network 1.1.1.0 the ping is working and in the virtual address there is no ticket icmp but in the spanning ticket is marked, but in any case if put TCP and not ICMP ping should’t work
so from my point of view i’m thinking that the is sending all the traffic that the vs_wildcard matching to the upstream firewall that has the same ip address that thas in the pool firewall
