VS not working
Hi
I have a VS working on port 80 and 443 with a irule, but for some reason it’s not working. but if i connect to the backend directly it works.
Irule
when CLIENT_ACCEPTED {
switch [TCP::local_port] {
80 {
SSL::disable clientside
SSL::disable serverside
pool pool_wlcmrbqa_http
443 {
pool pool_wlcmrbqa_https
here is the config for the VS
ltm virtual vs_wlcmrbqa {
destination 10.217.235.113:any
ip-protocol tcp
mask 255.255.255.255
partition CMRB
profiles {
/Common/http { }
/Common/wildcard.co.za {
context clientside
/Common/serverssl-insecure-compatible {
context serverside
/Common/tcp { }
rules {
wlcmrbqa_irule
/Common/CRM
snat automap
translate-port disabled
vlans-disabled
sorry i fugured our the problem translate-port needed to be enabled…
