I have a question about the VS matching algorithm. I have found a couple of references to the matching order for host and network based VSs, but nothing definitive covering two host based entries.
Assume I have the following VSs:
10.10.10.10:80 10.10.10.10:443 10.10.10.10:8080 10.10.10.10:*
In this case, since the wildcard VS also matches against traffic on ports 80, 443, & 8080, will it be used for that traffic, or since the other three VSs are more specific from a match perspective, will traffic to ports 80, 443, and 8080 match those specific VSs?
The traffic to the specifically defined VSs needs to be destined to different pools and undergo different treatment.
Here is a reference to the article I found on host/network VS matching algorithm.
https://devcentral.f5.com/questions/host-and-network-destination-address-difference
