VS and pool stats for SCP/SSH VS are not updated.
I’ve migrated our users to use a SCP (port 22) on a virtual server. After migration I am checking if users are connecting, etc. The stats don’t seem to update much so I inserted an iRule and that picks up many CLIENT_ACCEPTED and CLIENT_CLOSED. While the iRule stats are good to have, I would prefer to know existing client connections for current and max but those numbers don’t increase. I did a test SCP and SSH to the VIP and even after I connect the stats don’t increase.
Here is my statistics output (removed name/IP references for security): VIRTUAL ADDRESS UNIT 1 | ARP enable | (cur, max, limit, tot) = (0, 19, 0, 23076) | (pkts,bits) in = (1.510M, 9.250G), out = (1.274M, 5.888G) ±> VIRTUAL myscp_22 SERVICE 22 | PVA acceleration none | (cur, max, limit, tot) = (0, 17, 0, 3390) | (pkts,bits) in = (1.483M, 9.235G), out = (1.228M, 5.849G) | requests (total) = 0 ±> RULE myscp_log ±> CLIENT_ACCEPTED 3345 total 0 fail 0 abort ±> CLIENT_CLOSED 3351 total 0 fail 0 abort ±> SERVER_CONNECTED 3335 total 0 fail 0 abort ±> POOL myscp_22 LB METHOD round robin MIN/CUR ACTIVE MEMBERS 0/2 | (cur, max, limit, tot) = (0, 18, 0, 3330) | (pkts,bits) in = (1.712M, 9.334G), out = (1.189M, 5.822G) ±> POOL MEMBER myscp_22/xx:22 active,up | | session enabled priority 1 ratio 1 | | (cur, max, limit, tot) = (0, 9, 0, 1673) | | (pkts,bits) in = (418354, 2.003G), out = (299391, 1.357G) | | requests (total) = 0 ±> POOL MEMBER myscp_22/xx:22 active,up | session enabled priority 1 ratio 1 | (cur, max, limit, tot) = (0, 9, 0, 1657) | (pkts,bits) in = (1.294M, 7.331G), out = (889905, 4.465G) | requests (total) = 0
My rule: rule myscp_log { when CLIENT_ACCEPTED { set vip [IP::local_addr]:[TCP::local_port] }
when SERVER_CONNECTED { set client “[IP::client_addr]:[TCP::client_port]” set node “[IP::server_addr]:[TCP::server_port]” log connection info log local0.info “Client $client → VIP: $vip → Node: $node” }
when CLIENT_CLOSED { log connection info log local0.info “Client $client → VIP: $vip → Node: $node” } }
Any help is appreciated. Thanks.
VIRTUAL ADDRESS xx UNIT 1 | ARP enable | (cur, max, limit, tot) = (0, 19, 0, 23076) | (pkts,bits) in = (1.510M, 9.250G), out = (1.274M, 5.888G) ±> VIRTUAL myscp_22 SERVICE 22 | PVA acceleration none | (cur, max, limit, tot) = (0, 17, 0, 3390) | (pkts,bits) in = (1.483M, 9.235G), out = (1.228M, 5.849G) | requests (total) = 0 ±> RULE myscp_log ±> CLIENT_ACCEPTED 3345 total 0 fail 0 abort ±> CLIENT_CLOSED 3351 total 0 fail 0 abort ±> SERVER_CONNECTED 3335 total 0 fail 0 abort ±> POOL myscp_22 LB METHOD round robin MIN/CUR ACTIVE MEMBERS 0/2 | (cur, max, limit, tot) = (0, 18, 0, 3330) | (pkts,bits) in = (1.712M, 9.334G), out = (1.189M, 5.822G) ±> POOL MEMBER myscp_22/xx:22 active,up | | session enabled priority 1 ratio 1 | | (cur, max, limit, tot) = (0, 9, 0, 1673) | | (pkts,bits) in = (418354, 2.003G), out = (299391, 1.357G) | | requests (total) = 0 ±> POOL MEMBER myscp_22/xx:22 active,up | session enabled priority 1 ratio 1 | (cur, max, limit, tot) = (0, 9, 0, 1657) | (pkts,bits) in = (1.294M, 7.331G), out = (889905, 4.465G) | requests (total) = 0
Hi Victor,
what TMOS version are you on, please?
Is it a redundant deployment with mirroring enabled?
You are really monitoring the active unit and VIPs and floating self IPs are all assigned to traffic group traffic-group-1?
Could you please provide the config of your virtual server:
tmsh list ltm virtual virtual_server_name
tmsh list ltm virtual-address virtual_ip_address
Thanks, Stephan
Hi, I’m running BIG-IP Version 9.4.7 320.1. It is a redundant pair and I’m on the Active unit.
virtual myscp_22 {
   snat automap
   pool myscp_22
   destination xx:22
   ip protocol 6
   rules myscp_log
   profiles
      myscp_tcp
         clientside
      tcp-lan-optimized
         serverside
   persist source_addr
Hi Victor,
it looks straight forward.
I guess, your clientside tcp profile has just a modified timeout and is based on the default tcp profile?
Your virtual addresses and floating self IPs are all assigned to unit 1, right?
Sometimes I noticed a significant delay with the statistics updates.
But I was under the impression, that this might be related to still open connections. But you proved by your iRule, that this is not the case here …
Btw, as you are using the virtual server for SCP, it makes sense to run it in proxy mode. In case it would just be plain SSH, I would switch to Performance L4 to lower the introduced latency.
From my perspective this is a case for the F5 support folks.
Thanks, Stephan
Thanks for the feedback. Yeah, I don’t think it’s an issue with the unit or IPs themselves. I have other HTTP virtual servers all updating fine and quick. My tcp profile just extends the timeouts so users don’t get dropped too quickly in case of a long download. (These settings where actually pulled from a ftp profile that this VS replaced).
Thanks again. I’ll see what else to try, as I know support will probably tell me to upgrade :slight_smile: That is the plan in 2 months but at the moment, I am trying to get useful data back to mgmt.
Take care.
