Am looking to create a VPN tunnel for mobile users on f5 to be used with the edge client on Windows, am not able to find anything like that. The remote client who uses the edge need to have access to all network services (shared files, applications, etc..) Thanks,
Hello,
it’s easy to do it, you can follow this procedure:
So just keep in mind that you need 3 important things: - Webtop - network access (you will network behaviour: split or full VPN) - connectivity profile
as soon as you set this 3 things you can use an edge client (mobile or laptop).
How I can help you? you already try to deploy a VPN? on nothing for the moment…
Regards,
