Hello guys, i´m having an estranged behavior with a deployment over VPN´s. Right now I have a Cisco ASA _1on one side and on the other side anothe CISCO ASA_2 and in between is the LTM.
We are just passing traffic through the F5 between these two CISCO´s, the VPN is established but when passing traffic CISCO ASA_1 only see encrypted packets but no decrypted traffic.
Attached you will find the Diagram of the solution, the main issue happens with the RACSA ISP.
Here is an output of the VPN establishment:
17:09:07.175755 IP 190.14.195.19.isakmp > 172.17.151.98.isakmp: isakmp: phase 2/others R inf[E] 17:09:08.669858 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x16), length 92 17:09:14.169428 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x17), length 92 17:09:17.082335 IP 172.17.151.98.isakmp > 190.14.195.19.isakmp: isakmp: phase 2/others I inf[E] 17:09:17.176841 IP 190.14.195.19.isakmp > 172.17.151.98.isakmp: isakmp: phase 2/others R inf[E] 17:09:19.671852 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x18), length 92 17:09:25.170147 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x19), length 92 17:09:27.083718 IP 172.17.151.98.isakmp > 190.14.195.19.isakmp: isakmp: phase 2/others I inf[E] 17:09:27.177841 IP 190.14.195.19.isakmp > 172.17.151.98.isakmp: isakmp: phase 2/others R inf[E] 17:09:30.670244 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x1a), length 92 17:09:36.170279 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x1b), length 92 17:09:37.085515 IP 172.17.151.98.isakmp > 190.14.195.19.isakmp: isakmp: phase 2/others I inf[E] 17:09:37.179878 IP 190.14.195.19.isakmp > 172.17.151.98.isakmp: isakmp: phase 2/others R inf[E] 17:09:41.671189 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x1c), length 92 17:09:47.086735 IP 172.17.151.98.isakmp > 190.14.195.19.isakmp: isakmp: phase 2/others I inf[E] 17:09:47.170762 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x1d), length 92 17:09:47.180433 IP 190.14.195.19.isakmp > 172.17.151.98.isakmp: isakmp: phase 2/others R inf[E] 17:09:52.670852 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x1e), length 92 17:09:57.088412 IP 172.17.151.98.isakmp > 190.14.195.19.isakmp: isakmp: phase 2/others I inf[E] 17:09:57.184701 IP 190.14.195.19.isakmp > 172.17.151.98.isakmp: isakmp: phase 2/others R inf[E] 17:09:58.172094 IP 190.14.195.19 > 190.241.90.120: ESP(spi=0xf40c7478,seq=0x1f), length 92
Appreciate of someone has an idea of this behavior.
Thanks a lot
