2 issues:
1) Trying new plugins (F5 Networks 2.0.1.1) for VMware Orchestrator 5.5. Disabling and enabling pool member plugin not working correctly. Disables/enables a different pool member than one specified. Note: Debugging verified proper pool member was being specified.
2) Using CURL, my attempts to change the session state fails:
C:\Program Files\cURL\bin>curl -k -u admin: -H “Content-Type:application/json” -X PUT -d ‘{“session”:“user-disabled”}’ https:///mgmt/tm/ltm/pool//members/:80 {“code”:400,“message”:“Found invalid JSON body in the request.”,“errorStack”:[]}
C:\Program Files\cURL\bin>curl -fsS -k -u admin: -H “Content-Type:application/json” -X PUT -d ‘{“session”:“user-disabled”}’ https:///mgmt/tm/ltm/pool//members/:80 curl: (22) The requested URL returned error: 400 Bad Request
Currently using “BIG-IP 11.5.1 Build 0.0.110 Final” VMware virtual machine.
I would like to be able to use the plugins; however, I am concerned about their reliability. I am further at loss as to why the CURL PUTs do not work. Any suggestions?
