VmWare Horizon View 6.1.1 and F5 APM
Hello,
I’m building F5 configuration for VmWareview and I have some issues with it…
I’m using iapp 1.3.0 and I have 11.6. HF6 firmware running on F5 devices. I want to use APM because I need SMS-authentication for View. At the moment I’m able to launch virtual desktop with VmWareClient and it’s ok.
Problems: 1. I cant get HTML5 working. I have tried it with many different configurations, with ssl, with ssl-offload and I’m just getting error message “This webpage is not availabla ERR_CONNECTION_RESET” Connection server setting should be ok…
  1. Is it possible to get shared folders visible in virtual desktop? I mean those folders which I have in my own computer from where I connect to virtual server?
  2. USB redirect, is it supported when using F5 APM?
-JK
Regarding your question on USB redirect support, some zero clients such as Wyse P25 provided by Teradici use PCoIP as a transport for USB, and work with APM since 11.4.
VMware provided clients however redirect USB over their proprietary protocols. As of APM version 12.0-HF1, it is not supported. The support for it has been added in the upcoming 12.1 version.
Hello,
ok, thank you for your answer.
How about that shared folders, is it supported via F5 apm?
I haven’t got html5 connection to work, still getting this same error message “This webpage is not availabla ERR_CONNECTION_RESET”. I have gone through F5 configuration many times and I dont believe there is nothing wrong but maybe something on vmware connection server… Any help is appreciated.
-JK
Hello,
-JK
