VMware compatiblity with F5 devices
Hello,
I upgraded our VMware VM version to ‘vmx-10’ on our servers. My question is, does vm version vmx-10 work fine with F5 GTM’s and LTM’s devices?
I’m assuming there is no problem, but better safe than sorry.
Thanks!
In earlier releases, that was listed (example: Release Note: BIG-IP LTM Virtual Edition version 10.2.1 )
Since then not anymore. I would say that the highest virtual hardware version of the supported ESXi version is supported too. To be safe, open a case to F5 support to get a statement :slight_smile:
Ok great idea. Thank you!
did you ever get an answer for this as I am in the same position can’t find the supported vmx version anywhere for LTM 12.1 VE
