i’m using Difference VLANs to every Virtual Server on my LTM
VS1 Pool: 10.10.5.x 10.10.5.x 10.10.5.x
VS2 Pool: 10.10.4.x 10.10.4.x 10.10.4.x
the servers GW are the self ip of the BIG-IP (10.10.5.2 |10.10.4.2) I need to route traffic from my FW (10.10.5.1 |10.10.4.1) to the pools clients and back didn’t find any way to do it inside the BIG-IP
for now i set up a static route in each pool client, not a good solution…
i attached a diagram of my work flow, I hope its clear enough
For now the only way the IPsec client from the FW can access the real server is if i set a static route in the real server (net 10.3.3.3.0 GW 10.10.10.1)
I know that I’m doing something wrong, there must be a better way to set it up inside the F5
