Virtual LTM LAB help and advice.
Hi
I’ve finally managed to get hold of two lab licences and have VMware workstation installed on my laptop. I’ve looked into the software images but they are all for ESXi. Will these run on VMware (WS), can you suggest how best to setup the virtual environment or point me in the direction of helpful documentation on this subject.
regards
Alan
Hi there,
VMware workstation will accept and import an OVA without any issues same as ESXi would.
Should just be a case of “Import VM” supply the OVA and boot it up.
Regards
