I have doubts about the relationship between TMM and vCPU, because in one environment the same amount of TMM corresponds to the number of vCPUs made available for a Virtual Appliance.
In my case, I have a Virtual Appliance (version 13.1.1) with 6 vCPUs, 10G of memory, but only 4 TMM are active as output below. I would like to understand this relationship better and if there is any problem.
Sys::Host: 0
Global CPU Count 6 Active CPU Count 4
Memory (bytes) Total 9.7G Used 4.5G
Sys::TMM: 0.0
Global TMM Process Id 17137 Running TMM Id 0 TMM Count 1 CPU Id 0
Memory (bytes) Total 4.0G Used 606.0M
CPU Usage Ratio (%) Last 5 Seconds 3 Last 1 Minute 4 Last 5 Minutes 4
Sys::TMM: 0.1
Global TMM Process Id 17137 Running TMM Id 1 TMM Count 1 CPU Id 1
Memory (bytes) Total 0 Used 0
CPU Usage Ratio (%) Last 5 Seconds 4 Last 1 Minute 4 Last 5 Minutes 4
Sys::TMM: 0.2
Global TMM Process Id 17137 Running TMM Id 2 TMM Count 1 CPU Id 2
Sys::TMM: 0.3
Global TMM Process Id 17137 Running TMM Id 3 TMM Count 1 CPU Id 3
