The virtual prod_https_vs is using the pool prod_https_pool, the current connections quantities is far from the same. What may be the explanation for this?
show ltm virtual prod_https_vs
Current Connections 4.9K
show ltm pool prod_https_pool
Current Connections 751
Do you have any Oneconnect and/or Persistence profile configured on the vServer ?
Then the results that you are seeing are normal. Due to oneconnect profile, exiting idle connections gets reused while sending request to the pool member. So the new server-side connection won’t be initiated with pool member if the existing idle connection is available for reuse for other client requests.
ok, that make sense, thank you
