Viprion VCMP deploy AVR module issue
Hi all,
I have deployed some VCMP with 2 core cpu and enabled LTM, ASM and AVR. Recently I have found that there is one vcmp appeared memory leak issue caused bd_process restart. And then I heard that it is because the AVR is counting as 2 modules at this vcmp environment. (2 core cpu will have ~5.8GB RAM).
I am so confused why it would count as 2 modules. Is it a proper way to enable those modules in 2 core cpu vcmp platform?
Thanks a lot.
Cawong23,
Afraid not. If you check a tmos release platform support section from release notes it says: “Analytics (AVR) counts towards the two module-combination limit (for platforms with less than 6.25 GB of memory).”
Also, ASM needs 2 cores also. So a 2 core setup could have LTM+ASM but no other modules I’m afraid.
N
