Yes, this should be possible, but why not create your guests across the blades. That way if one blade goes down, your guest keeps on running and you get extra resilience. Make sure to create network trunk links that also span both blades if you do it this way.
We did this design because we need to replace their existing 4qty x F5 units and we are bind to the number of physical ports previously connected to it. Also we don’t want much changes on the network.
