Zdenda
May 30, 2016, 10:09am
1
Hi, have blade 2250 in chasses 2400 running 11.5.3 HF2 and I need to change mgmt IP. I am connected via console and using these commands:
delete sys management-ip 192.168.2.10/20
create sys management-ip 1.2.3.4/24
But when I use show sys management-ip, I still see the original one. I tried to save config after removal of old mgmt IP, reboot whole chasses, but nothing works.
Thanks for any advice, Zdenek
You do not need the delete command. You can just modify the IP via TMSH, the previous one will be over-ridden naturally.
Assuming your blade 2250 is in slot 3, you can change it’s mgmt IP (aka. cluster member IP address) as follows:
Modify Mgmt.IP:
tmsh modify sys cluster default members { 3 { address 1.2.3.4 } }
Save config:
tmsh save sys conf
(note you must do these changes from your primary blade)
Modify Mgmt.IP:
Save config:
tmsh save sys conf
Zdenda
May 30, 2016, 10:33am
4
yeh, I just found it as well, my bad - I have too short memory Thanks Anyway
Zdenda
5
