What should be done to make sure that vGuest (which is in standby status) during mirgation to another blade unit won’t go active ?
Hi @T5C , set the guest state to configured while you do your migration, and when complete, can change the state back to deployed. It will not be able to be active while in configured state. See Solution K52477511 for details.
I’m honestly surprised I couldn’t find an instance of someone else asking this question. Glad you did and that you marked Jason’s reply as an Accepted Solution, so the next user can easily find the answer! So much so that I had to feature this in this week’s Highlights article. ![]()
