VIPRION HA Configuration
Hello DevCentral,
I was interested to know the HA configuration for 2 VIPRIONs. Though I have worked on VIPRIONs many times, I have not done the initial setup before.
Do you configure HA at the chassis level and again at the guest level, or do you just leave the 2 VIPRION chassis as standalone and ONLY configure HA at the guest level.
I tried HA at the chassis level and it did seem to work, they did go active / standby - but did not seem to change to “changes pending” if I made any changes as the Chassis level. Also I was wondering if the Chassis is in Standby, then is it possible to have an active guest on a standby chassis.
I just looking for some pointers, I know how to configure HA groups, but just not 100% sure what is best practise on the VIPRIONs
Many Thanks Graham
chassis is configured as standalone. only guest is ha pair.
Hi Nitass,
Thanks very much for your quick answer.
Graham
