Hi; I have two viprion c2400 chassis .Each chassis has two blade b2100. firstly I put both blade on the same chassis and I did configuration. but then I removed from one of them and I put an other chassis for Failover testing but I didn’t to configuration also I could not manage on the https:// (gui) but When I connected to cli I saw some errors mesage e.g.: root@bld:/S1-(none)-S:INOPERATIVE] config ,snmpd[5314]: error on subcontainer ‘ia_addr’ insert (-1), snmpd[5314]: IfIndex of an interface changed. Such interfaces will appear multiple times in IF-MIB. now what Must I do What is your suggest? thanks for your support and help
